02-18-2010 04:27 PM
I have a legacy core implementing the plb34 interface. I would like to excercise this core using software on a microblaze, so I created an EDK system with a microblaze on an opb bus, a opb2plb bridge, and a plb bus. As a sanity check, I put a bram on the plb bus, to ensure that I could read and write to the bus.
However, I'm having trouble. If I try to write to the BRAM, nothing happens, and I get a constant return value of 0 for my writes (I've made the pointer nonvolatile and disabled the cache).
I'm wondering if perhaps I've misconfigured something. My bridge has address range 0x10000000 to 0x1fffffff, and the bram has (plb) range 0x10000000 to 0x10007fff.
Does anyone have experience with this sort of design? Id I had a working EDK project with something like this in it, I think all my problems would be solved, so if you could send one, that would be great.
I can post more information if necessary.
Elliott
02-18-2010 06:36 PM
The ML405 MicroBlaze reference design includes a opb2plb bridge to access the PLBv3.4-based TFT controller:
http://www.xilinx.com/products/boards/ml405/reference_designs.htm
Cheers,
bt
02-18-2010 09:18 PM
I have had problems with PLBv46 to OPB connections before as the timeout logic on OPB and PLBv3 buses do not match up with the new v46 spec. For me, under heavy bus load, reads to the OPB return all zero's even to addresses that should always return non-zero values. I never get a bus error or timeout though (verified with ChipScope).
I would recommend looking at the system.vhd file located in your EDK sub-directories just to make sure that all of the proper clock and reset signals are connected up to each of the buses and bridges.
Does the core have a master or slave interface (or both). If it is slave only, it is very easy to convert to the newer bus specification. Master interfaces take a bit more work, but the createip tool can build most of the interface for you.
-Jason
02-19-2010 01:55 PM
I see. Unfortunately, it is a bus master. I suppose I might be able to hack up some bus bridge. Maybe one already exists? This seems like something Xilinx should provide for convience.
I did add a reset block to the system, since there was some documentation that stated a reset of at least 2 cycles was needed.
So, the idea is that opd may timeout and just return a 0? There is some parameter that deals with this. Did you try tweaking it?
02-21-2010 01:55 PM
I notice this variable:
PARAMETER C_NUM_OPBCLK_PLB2OPB_REARB =100
in the 8.1 sample code. I copied this in to my mhs, but it did not seem to work. Hmmm.... I suppose I can copy my mhs params for comment:
BEGIN plb_v34
PARAMETER INSTANCE = plb_v34_0
PARAMETER HW_VER = 1.02.a
PARAMETER C_EXT_RESET_HIGH = 1
PARAMETER C_NUM_OPBCLK_PLB2OPB_REARB = 100
PORT PLB_Clk = sys_clk_s
PORT SYS_Rst = proc_sys_reset_0_Bus_Struct_Reset
END
BEGIN plb_bram_if_cntlr
PARAMETER INSTANCE = plb_bram_if_cntlr_0
PARAMETER HW_VER = 1.00.b
PARAMETER c_include_burst_cacheln_support = 1
PARAMETER c_baseaddr = 0x10000000
PARAMETER c_highaddr = 0x10007FFF
BUS_INTERFACE SPLB = plb_v34_0
END
BEGIN opb2plb_bridge
PARAMETER INSTANCE = opb2plb_bridge_0
PARAMETER HW_VER = 1.00.c
#PARAMETER C_OPB_HIGHADDR = 0x100FFFFF
#PARAMETER C_RNG0_BASEADDR = 0x10000000
#PARAMETER C_RNG0_HIGHADDR = 0x1fffffff
#PARAMETER C_SAME_CLKS = 1
PARAMETER C_NUM_ADDR_RNG = 1
PARAMETER C_RNG0_HIGHADDR = 0x1FFFFFFF
PARAMETER C_RNG0_PREFETCH = 0
PARAMETER C_RNG0_LINE = 0
PARAMETER C_OPB_REG_INTFC = 0
PARAMETER C_DCR_BASEADDR = 0b0000001000
PARAMETER C_DCR_HIGHADDR = 0b0000001011
BUS_INTERFACE SOPB = mb_opb
BUS_INTERFACE MPLB = plb_v34_0
PORT BGI_Trans_Abort = net_gnd
END
BEGIN opb_v20
PARAMETER INSTANCE = mb_opb
PARAMETER HW_VER = 1.10.c
PORT OPB_Clk = sys_clk_s
END
