operator && has no left operand,error in Xilinx preprocessors?
I am mixing a C and C++ project and after dealing with some errors I reached a point where I can't find any error .
I declared in main
#define __cplusplus
and then the errors in the bsp were ingored but those refuse to dissapear
https://image.prntscr.com/image/kG8zxtEaTWmzFmCc7ZkhHg.png
I have no errors in my project.I tried to clean the project,delete some files,could some variable change in project settings?
Re: operator && has no left operand,error in Xilinx preprocessors?
The problem was not from using extern C++ or C even if one created more errors.I could import any files in any way in the project the errors would be the same.
The solution was to import first a bsp header then use my code,not use my code in which I import a bsp header...
@tester11 you should never define that
It is defined by the compiler
Then I get more 'undefined reference to' in bsp
@tester11 what are the file extensions? C++ files should be on .cpp and c files on .c
