petalinux 2016.04 firmware version is not reflecting in /etc/version
     I am using petalinux 2016.04. I noticed that firmware version is not reflecting in /etc/version whereas same is happening in petalinux 2014.04.
INPUTS :
1 . On board =>
root@plnx_arm:/etc# cat version
20171019083148
2 . petalinux config =>
Firmware Version Configuration  --->
 (2.00) Firmware Version
How can I get the expected result in /etc/version.
Any help will be appreciated.
Pritam
Re: petalinux 2016.04 firmware version is not reflecting in /etc/version
you can do that in bb file itself
something like
sysconf = "${TOPDIR}/../project-spec/configs"
FILESEXTRAPATHS_append := ":${sysconf}"
SRC_URI_append ="\
    file://config\
do_install () {
firmware=$(cat config | grep SUBSYSTEM_FW_VERSION |  cut -d '=' -f 2 | tr -d '"' )
< your code >
adding SRCURI also solves the dependency issue, means for every change in petalinux-config, it will rebuild
Mentor
Mentor
Hi @pritya
I'm not sure what did you do by petalinux.
But, if you don't modify rootfs file, it doen't change it at least.
[Note]
If you'd like to know kernel version, I recommend to use "lsb_releas" command or "uname" command, if you prepare on your linux kernel and rootfs.
Thank you.
Best regards,
   I am beginner to petalinux.
   I have used following steps to create project and images.
1 . petalinux-create --type project --template zynq --name <PROJECT_NAME>
2 . petalinux-config --get-hw-description=<path-to-hardwaredescription-file-directory-exported-by-Vivado>
3 . petalinux-build
4 . petalinux-package --boot --fsbl images/linux/zynq_fsbl.elf --fpga <FPGA bitstream> --u-boot
And board is booted by same images.
But in Petalinux_2014.04 "build/linux/rootfs/sys_init/Makefile +137" I can see clear command that version is being written.
Whereas in Petalinux_2016.04 I am not able to see such a Makefile.
So Where time-stamp is getting written to /etc/version from ?
from 2016.4 onwards petalinux is using Yocto under neath, which changed many of things
Thanks for your reply.
Is there not any other way that I will have fix version string rather than time stamp ... ?
How time stamp is getting written to /etc/version  ?
This is the patch
https://github.com/Xilinx/meta-petalinux/commit/5586c987c88f40f1454e6bd06250f17175faa6ed
add the bbappend in meta-user
Thanks for this valuable reply.
And I would like to use "SUBSYSTEM_FW_VERSION"  in version.
ATTEMPT :
So that I have created a app and inside Makefile of app, I have included "project-spec/configs/config".
I am directing CONFIG_SUBSYSTEM_FW_VERSION to file fw_version. Finally I am installing this fw_version file in RFS.
App files I have attached below.
The ATTEMPT that I used is not proper.
So in above patch, recipes-core/base-file/bbappend file,
how can i import/include "project-spec/configs/config" file to bbappend ?
So that in RFS, I can use some of the symbols like "SUBSYSTEM_FW_VERSION".
Any help will be appreciated .
something like
SRC_URI_append ="\
    file://config\
do_install () {
< your code >
Appreciated and thanks for this solution.
give kudos to the solution :)
You have to look at /etc/petalinux/version; not /etc/version
