petalinux installation Failed
I m trying to install petalinux on ubuntu 16.04
I find this error:
My pc : I5
RAM IS 3.8gb
HHD IS 56 GB
I wonder ask about this error exactly
is it related to memory because in this PDF
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1144-petalinux-tools-reference-guide.pdf
it mention that It require
The PetaLinux Tools Installation requirements are:
Minimum workstation requirements:
4 GB RAM (recommended minimum for Xilinx tools)
Pentium 4, 2 GHz CPU clock or equivalent (minimum of 4 cores)
100 GB free HDD space
Supported OS:
RHEL 6.7/6.8 (64-bit)
PLEAASE I need help
Mentor
Mentor
Re: petalinux installation Failed
Hi @kanzali
Would you make sure your disk space with the following command ?
% df -k
Filesystem            1K-blocks       Used  Available Use% Mounted on
/dev/mapper/os-lv_root
                      951779300  855688636   47747528  95% /
tmpfs                   8040320     113416    7926904   2% /dev/shm
/dev/sda3                487652     228636     233416  50% /boot
/dev/md126p1          976270576  940313784   35956792  97% /home
Here is my environment.
You can find free space on /opt.
If I am you, free space is about 45GB.
I'm sure it is OK to install petalinux.
But, I guess, this free space is not enough to install petalinux.
Would you make sure it ?
Best regards,
