rdb9879
petalinux on zynq: update *.bit file from Windows host
Greetings,
We do most of our Vivado development on a Windows host. Right now, when we make a modification to the *.bit file, we have to generate a *.hdf file, transfer that to a linux machine, run petalinux-config --get-hw-description=..., petalinux-build, petalinux-package, and finally transfer the *.BIN and uImage.ub back to Windows to load onto an SD Card.
Are there any Windows based tools or methods that would allow us to take an existing image and just update the *.bit portion, without booting up the linux machine? I understand this would be limited to minor changes (nothing that would require an updated device tree).
johnmcd
If you are only changing the .bit, then you can use bootgen on the windows machine to repackage the necessary files into a new BOOT.BIN which gets copied onto SD.
Bootgen uses a .bif file to describe the contents of BOOT.BIN. So copy onto windows the petalinux generated files from the 'images' dir: bl31.elf and u-boot.elf
Also, either copy from linux, or create on windows SDK using same hdf: fsbl.elf, pmufw.elf
and get your .bit
Now create a .bif file with contents something like:
my_image:
    [bootloader, destination_cpu = a53-0]            ./fsbl.elf
    [destination_cpu=pmu]                                   ./pmufw.elf
    [destination_device=pl]                                   ./my.bit
    [destination_cpu=a53-0,exception_level=el-3,trustzone] ./bl31.elf
    [destination_cpu=a53-0,exception_level=el-2]                ./u-boot.elf
And then in sdk, select create boot file and point to the above created .bif. Make sure your paths are correct. Or just use the sdk gui to create a .bif that looks comparable to above.
Personally, I create a windows shortcut to run something like the following:
%SystemRoot%\system32\cmd.exe /k C:\Xilinx\SDK\2017.4\settings64.bat
And then from that dos window, you can enter the command:
bootgen -w -image my_boot.bif -arch zynqmp -o BOOT.BIN
johnmcd
and get your .bit
my_image:
stephenm
If you are changing the HW. Then you would prob be advised to update the devicetree too.
You can use the SDK to update the devicetree. You would need to source the devicetree generator from git hub. See the wiki article below:
http://www.wiki.xilinx.com/ZCU102+Image+creation+in+OSL+flow
The flow here uses hsi, but you can add the repo directory in the xilinx tools -> repositories. Then just create a nap with os set to devicetree.
You would need to compile the DT too using the DT compiler. Then just place the image, dtb and the roots on your SD card (assuming you are booting from SD), and use the uboot bootm command to boot Linux
