sharmilakotra123
petalinux_zynq_pencv
i want to run the opencv simple application in zybo board using petalinux...
- i was partition the sd card into boot and root and also include opencv livraries
-1st partition contains the boot.bin and image.ub files and 2nd partition contains extracted rootfs
-where i copy the ex: face_web.elf opencv file in sd card (if want to copy it in root filesystem how can i copy)
-and how can i run this one from scrach with commans can anyone help me out.
K sharmila
nutang
Hi @sharmilakotra123
You can use scp to copy your application in home directory
Best Regards,
Nutan
