ank_mistry
platgen failed with errors!
I have been working with EDK to build an Ethernet project for Spartan 6 LXT device. But I'm unable to build project, it ends up with error like
ERROR:EDK:546 - Aborting XST flow execution!
ERROR:EDK:440 - platgen failed with errors!
make: *** [implementation/abcd.bmm] Error 2
I do have my old project which was for Spartan 6 LX device and was successfully build and tested. Now when I'm trying to build that same project after cleanup, it is also throws out  same error.
I have even tried reinstalling ISE again but didn't help.
Please help me out
Anonymous
Not applicable
You should be able to see what the issue is in the system.log file
ank_mistry
I went through system.log file and didn't find any error or warring that is giving rise to this error.
By the way if there was anything wrong with project then my old project should not have build previously.
