08-07-2009 10:26 AM
I am trying to upgrade an older system using plb 3.4/opb interfaces to the plb_v4.6 interface and am having trouble with the memory controller upgrade. I've read that the PLB_DDR memory controller provides a big endian connection to devices whereas the MPMC controller provides a little endian connection. I know I need to swap pins to match the endianess, but does that mean I should swap all pins, just address pins, or just data pins?
Any suggestions?
--David
08-08-2009 12:16 AM
Hello.
As far as swapping is concerned to tackle the big endian format you have to reverse every signal which is a vector.
Like address, data, DM, etc....as far as SDRAM is concerned.
