Visitor tronix
problem taking input from hyperterminal-help!!!
i am using EDK 10.1 and Spartan 3E
i had written a very basic code to take two integers from the user and display the sum. the code looks something like this
#include "stdio.h"
int main(void)
         int a,b,c;
         xil_printf("enter the first no:");
         scanf("%d",&a);
         xil_printf("enter the second no:");
         scanf("%d",&b);
        c=a+b;
         xil_printf("result is %d",c);
        return(0)
the hyperterminal receives the first no. but does not accept the second no and the result displayed is a garbage no.
I dont  know what the problem is.pls help
Re: problem taking input from hyperterminal-help!!!
Hello.
Try this code and also compare your code with this.
Note:Do check your base address for UART controller.
#include "xuartlite_l.h"
#include "xio.h"
main()
Xuint8 data1,data2,sum;
xil_printf("\n\rEntering MAIN\n\r");
while(1)
data1 = XUartLite_RecvByte (baseaddr);
data2 = XUartLite_RecvByte (baseaddr);
sum = data1+data2
xil_printf("\nSUM=0x%x", sum);
Best of luck.
Unlimited in my Limits.
Visitor tronix
Hey
Thanks alot tat code worked out for us .
I have one more doubt for - are pointers acceptable in sdk? We are workin on Hauffman codec for which we need to creat trees and so we need pointers. Can u pls throw some light on this problem.
Thank you.
Hello.
As far as pointers are concerned its a feature of C language.
SDK supports C so i don't think there is any point for unacceptance of pointers in SDK.
Pointers are not tool dependent.
Although i haven't used SDK much but its logical.
Message Edited by prateek_bhatt on 11-21-2009 12:55 AM
Best of luck.
Visitor stone9502
Pointer can be used for sure, I am using it. Please note that once you use malloc() function or c++ new operation, be sure that the heap size is set correctly in the linker script so that you can manage the memory.
