fakefakefaker
problem when using memory test in vitis
i'm trying to use the memory test example to test my bram interface on my board (vc707)
Every time I build an application, an elf file is not created.
(elf.size file is empty)
(It works well when i use a hello world.)
(I used memory test well until 2 days ago, but it didn't work since yesterday.)
pvempati
OK great @fakefakefaker .
The reason for this could be due to elf sections pointed to different memory and now to another memory(8kb).
But ideally for VC707 microblaze designs the local bram memory should be more than 8kb. 32KB is enough for applications to build.
pvempati
HI @fakefakefaker ,
The problem you mentioned is quite interesting. since it used work few days and suddenty started failing. You can do below things
1) Try clean project and then build the application again
2) Restart the Vitis and try step #1
3) Now create the same project in new workspace and then try building the application.
Thanks & Regards,
Praveen Kumar. V
fakefakefaker
thx @pvempati
I tried using the method you wrote, but vitis still don't create an elf file.
Besides, I reinstalled it after formatting it, and it's the same.
Is it a license issue?
fakefakefaker
thx @pvempati
I solved this problem.
I set the local memory to 8kb until now, but it worked enough.
However, I don't know why, but now it works only when the local memory is set to 32 kb or higher.
pvempati
