problem with platform USB II
I am facing some problem while installing Platform cable USB II.
My infrastructure is like this:
ISE 10.1 with serviece pack 3.
O.S.: linux (Debian lenny).
USB cable II model DLC10
Driver is libusb
I have followed the procedure explained in ug344, and xilinx answers 29310, the problem is after that  if i connect my Platform Cable USB II  amber light glows for few seconds and goes off. I could not trace whats the problem is , while it is working fine with  parallel cable IV .
Did any one face this problem?? or am i doing any mistake ?? please guide me ..
when i do auto connect from impact  i am getting following error:
File version of /opt/ise-10.1i/ISE/bin/lin/xusbdfwu.hex = 1030.
File version of /etc/hotplug/usb/xusbdfwu.fw/xusbdfwu.hex = 1021.
 libusb-driver.so version: 2007-11-10 18:01:49.
Please run `source ./setup_pcusb` from the /opt/ise-10.1i/ISE/bin/lin directory with root privilege to update the firmware. Disconnect and then reconnect the cable from the USB port to complete the driver update.
though i have done ./setup_pcusb.
Thanks in advance
regards,
Krishna Kishore
