laxerez
problem with xmd
hello all!
I trying to download elf files with xmd (which opened from xps) and when I write "dow hello_world_0.elf" to download the c file "hello world", I get a message - "ERROR: Failed to download ELF file
UNABLE to open file : hello_world_0.elf".
How can I solve it?
thanks
stephenm
did you navigate to the correct directory where the elf file is located?
laxerez
I just writted "dow hello_world_0.elf"
stephenm
Can you try nagivate within XMD (ie change driectory, cd <path to folder that contains your elf file>) and try again?
