problems using chipscope
I'm doing the ChipScope & Embedded Processor Lab to learn how to use the ChipScope in a XPS project. I went to Debug->Debug Configuration.... in order to add a chipscope to the project.
I took the folows options:
1)Click the Add Chipscope Peripheral... button
2)Selected the first option, To monitor OPB bus signals (adding OPB IBA)
3)Click to put a check mark in the Enable Hardware/Software Co-debug field
With that I creteted two peripherals named chipscope_icon_0 and chipscope_plbv46_iba_0.
Then I want to generate the Netlist but there are errors. The XPS Output says
Running DRC Tcl procedures for OPTION SYSLEVEL_DRC_PROC...
Check platform configuration ...
IPNAME:plb_v46 INSTANCE:mb_plb - C:\EDKprojects\EDK-Labs\LAB6-2\system.mhs line
48 - 2 master(s) : 9 slave(s)
make: *** [implementation/microblaze_0_wrapper.ngc] Error 2
IPNAME:lmb_v10 INSTANCE:ilmb - C:\EDKprojects\EDK-Labs\LAB6-2\system.mhs line 55
- 1 master(s) : 1 slave(s)
IPNAME:lmb_v10 INSTANCE:dlmb - C:\EDKprojects\EDK-Labs\LAB6-2\system.mhs line 62
ERROR:MDT - IPNAME:mdm INSTANCE:debug_module BUS_INTERFACE:SPLB -
C:\EDKprojects\EDK-Labs\LAB6-2\system.mhs line 137 - invalid bus interface in
use when ISVALID="((C_INTERCONNECT == 1) && (C_USE_UART == 1))" evaluates to
FALSE. Please remove the bus interface from your design!
ERROR:MDT - platgen failed with errors!
Done!
What can I do to fix the problem?
I'm using the 10.1 version with the last update.
you can get past the error by setting the C_USE_UART = 1 for the mdm module. Either edit the .mhs file directly or right click the mdm/ debug module in XPS and select "configure IP..." and check "Enable  JTAG UART".
I don't know if doing this it will cause any other problems later...
HTH
Magne
