fmoraes
ps7_init command takes a long time in remote access
I am using Vivado/Vitis 2019.2 to remotely access a Pynq board. The hardware design is a basic Zynq design, just to execute a Hello World app also remotely. The remote computer, the one is connected to the board, is running the hw_server.
The Vivado remote access and bitstream programming went well. It's almost as quick as the local access. The issue is with the Vitis part, to download the Hello World app. It works but it takes more than 10 minutes. This is the script used in Vitis:
connect -path [list tcp::1534 tcp:my_remote_ip_address3121]
targets -set -nocase -filter {name =~"APU*"}
loadhw -hw /home/...../hello_world_pynq_vivado_2019.2/pynq-plat/export/pynq-plat/hw/design_1_wrapper.xsa -mem-ranges [list {0x40000000 0xbfffffff}]
configparams force-mem-access 1
stop
source /home/..../workspace/pynq-sw/_ide/psinit/ps7_init.tcl
ps7_init   <====
ps7_post_config
targets -set -nocase -filter {name =~ "*A9*#0"}
rst -processor
dow /home/.../workspace/pynq-sw/Debug/hello.elf
configparams force-mem-access 0
con
The command 'ps7_init' is the one taking a long time. Why is that happening (taking about 10 min to run it) ? is there a way to fix this ?
Best regards,
Alexandre Amory
marcb
Hi @fmoraes
I wasn't able to see the same delay. For the first line, could you try "connect -host <hostname> -port 3121" instead?
Also, I see the IDE generated script under .sdk/ adds a reset. Does this help?
# rst -system
# after 3000
stephenm
This would be expected, what you are doing with the ps7_init.tcl is writing to the registers one at a time over a network.
If you want to speed it up then use the FSBL
stop
#ps7_init   <==== comment this out
dow zynq_fsbl.elf
con
after 500
stop
ps7_post_config
rst -processor
con
