abilashbhojan
regarding SDK in zynq
Hii,
Im working on zynq board. in the vivdao tool when i tried exporting the hardware to SDK there was an error showing
"the folder c:\documents\.metadata" is read only .. so i couldn use SDK because of this.. could anyone suggest a better way???
Abilash B
anusheel
Are you working with example project?
If not, elaborate your query.
Anusheel
Search for documents related to your device and tool before posting query.
Please mark the post as an answer "Accept as solution" in case it helped to resolve your query.
Give kudos for accepted solution.
vuppala
Also provide your steps to reproduce the issue?
And do you have complete read/write permissions for the following folder "C:/documents/"
Vinay
abilashbhojan
hi,
ya exactly. im working on a example project bt i saved it in a diffferent name.. wat could b d issue????
thanks,
Abilash B
pulim
Can you try saving it in any other folder to which you are having complete read/write permissions?
anusheel
Check your permissions.
List out the steps you have follwed so we can assist you accordingly.
Anusheel
tyler.wilson
I am having the same issue. I am following the following tutorial:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug940-vivado-tutorial-embedded-design.pdf
When I attempt to export and launch the SDK, it gives me the same error as previously discussed in this thread. Also, when trying to move some files around and ensuring that the permissions are correct then I get this error:
An internal error occurred during: "Importing Hardware Specification".
java.lang.NullPointerException
Thanks for the help and suggestions,
Tyler Wilson
tyler.wilson
I did Lab 4 which begins on page 69 of the pdf link
tyler.wilson
I found my solution. It was a little strange. I had a few folders named similar to this:
Project Test
Project FirstTime
Project LookHere
Apparently this seemed to confuse the SDK when exporting. I simply had to change my folder names as follows and everything worked great:
Project_Test
Project_FirstTime
Project_LookHere
Hopefully this will help someone else.
bejcy
helps me a lot :)
worship21cc
Thanks for good solution!!
thilina777
Helped me too! Thanks.
hi
i am using vivado 2018.3 and i am not able to launch sdk.
iam getting an error .metadata is read only
