sdk 13.2 add custom ip driver
I designed a custom IP but i cannot load the driver in the sdk,in bsp i can choose only : none and generic.
Thank you.
Re: sdk 13.2 add custom ip driver
This is a known issue.
To work around the problem, perform the following:
  1. Create a user repository, C:\\(if you do not already have one).
    For example: C:\edk_user_repository\MyProcessorIPLib\
    NOTE: The above directory structure is not in the XPS project nor SDK project.
  2. Copy the "drivers" folder from your project to the above folder. So, you should have:
    C:\edk_user_repository\MyProcessorIPLib\drivers\\
  3. In SDK, add the global repository by selecting Tool > Software Repositories, and add C:\edk_user_repository.
Now, if you go to Tools > Software Platform Settings, you should be able to select the driver.
Can you see if this helps, there are a few answer records about this problem.
Kind regards,
Gareth
Kind regards,
Gareth
Kind regards,
Gareth
Kind regards,
Gareth
It solved the problem!Thank you very much.
No problem, I am happy to help.
Kind regards,
Gareth
hi
I am not sure if my problem relates to this probelm, but it sees very similar
I am also using DS13.2.
I created custom IP form "Hardware -> Create or Import Peripheral".
Made sure "Generate template driver files ..." ticked.
See the folder "drivers/src" with the relevant .c and .h files.
In SDK, created a standalone_bsp.
In the peripheral drivers ection of the system.mss I can see my IP with "generic" type driver.
I guess that is fine since I did not write my driver (it was generated, as described above, when I created the IP).
But the problem is I don't see the .h file under the
standalone_bsp/microblaze/include
folder (project explorer) in SDK.
So if I now write an empty application, and put in my .c file an include for the .h of my IP
#include "led_ip.h"
 it cannot find the .h file
../TestApp/lab4.c:4:20: error: led_ip.h: No such file or directory
Any advise on why this "generic" driver does not cause the .h to be put in the folder
thanks
Dag
#include "led_ip.h"
No ,you should not using "generic"  type for it is not a generic one but a custom one.
Just do as   told ,and you will see a new type besides "none "and "generic ",it is your custom IP driver.
FOLLOWS:
4. Go to Tools > Software Platform Settings, you should be able to select the driver,type is not "none"nor "generic",but your IP type.
Thanks to  agian.
Hi guys,
any updates on 14.1 regarding this particular issue?
I am simply unable to find out how to include the driver of my custom IP.
Any help appreciated!
Best Regards,
David
Sorry, I mean that the above mentioned "Tools -> Software Platform Settings" seems not to exist in 14.1. Also, "Tools -> Software Repositories" is now "Xilinx Tools -> Repositories". An update on that very same procedure but for 14.1 would be great. Thanks in advance!
Yes,it has changed its name to "xilinx tools"which is the same to "tools",and you can find "Repositories" as the same function.Good luck!!
> any updates on 14.1 regarding this particular issue ?
No updates on 14.1 and 14.2. The issue has not been resolved. I have reported several times with webcase. The last time I was told that in version 14.2 have been fixed, but it does not. I hope someday you solve.
secureasm
Participant rakesh05
Hello All,
              I have created my own peripheral in xilinx xps 13.1 and exported to sdk and created a dts file. With that dts file i have generated elf file but i dont have drivers for my own peripheral in linux. so, how to develop a driver for my own peripheral in linux.Please give me a way to solve this problem.
Thanks in advance
Hi , To,Xilinx Employee I am not able to add custom IP driver..I mean I am not getting the driver specfic in drop down menu list..I followed the solution mentioned over here..so , may i know where exactly I am going wrong... (sdk 14.4)
Hi Sweta
Can you create a new forum post for this topic? For analysis, do attach your design.
--Hem
ok done...htsvn
I'm having this problem as well. But mine is worst since I can add one f the modules but not the other -_-
Tried everything so far, please help me: http://forums.xilinx.com/t5/Embedded-Development-Tools/Can-t-find-one-of-two-drivers-even-though-it-is-in-hdf/m-p/646131/highlight/false#M37472
Observer yingcai
Thanks!
