Anonymous
Not applicable
sdk 15.1 bsp library problem
When the hardware platform is modified in Vivado and the new hardware platform is opened in Xilinx SDK, I re-generate the BSP. However the packages(librarires) for the new added hardware is not added to the BSP. The workaround solution is to create a application project with the new hardware platform. However this takes too much time for every creation of hardware platform. Is there any way to regenerate the BSP with the new added libraries in SDK?
hi,
so the changes in hardware platform would have newly added peripherals or would that only have newly added libraries?
refer to the help contents of the SDK to see what can be incorporated if there is a specification change.
if this is not working as expected, share the example with files.
--hem
