mthendricks
sdk debugger: suspend button greyed out
I have started debugging a project running on the microblaze.using the SDK.  When I initiate a debug session, the GUI gives me run/resume button, but the suspend (pause) button in greyed out.  Once I start a run, I'm only given the option of terminating the debug session. All other debug buttons (and menu items) are grayed out. I can't pause it and look at variables etc. What must I do to have an active suspend button?
As an aside, at the bottom of the Debug perspective, I can click the XMD tab.  From this tab I can type "stop" and "con" to do this.  Why won't the GUI give me the same functionality?
System:
Spartan 3a-DSP 1800 eval board
EDK/SDK: 10.1
OS:  ThreadX
purplebox
I have exactly the same issue using version 12.3 on a 64-bit Windows 7 machine.
Does anybody know what the issue is and how to fix it?
David.
mthendricks
I am using version 11.5 of the SDK, and when I click the "run" button, the pause button is always greyed out.  What you have to do is, after clicking "run,"  select your thread in the debug window.  In my case there is as thread called "Thread[0](Running)" in the Debug window in the upper left of the SDK.  When I click this, the pause button magically regains its color and can be used.
butowski
I have the same problem under 12.4 and Windows 7 x64.  The button is grayed out however i can type stop into XMD Console to interrupt the processor.
jjurack
I am having the same issue, again on 64-bit Windows 7, with version 13.1. XMD stop works for me, but clicking on "Thread [0]" doesn't work.
vsiva
Only applies to 13.x on Win64: http://www.xilinx.com/support/answers/41225.htm
jjurack
Thanks, that works great! One thing, though: you linked the wrong attachment -- that's the patch, not the zip file.
I've tried the link to get the answer, but it points to no answer-record.
drbyte
same problem with VIVADO 2016.1 and Win10 x64 machine.
I can run the debug (GDB) and use the step mode (step into and step over) but when I choose to resume I'm unable to stop the debug and the only option is the red button (Terminate CTRL+F2).
Could you please let me know how to overcome this problem?
drbyte
Just an update I'm able to solve the issue by a BSP rebuilding.
Best regards
