pavithra
signals regarding to acess the bram
hi
i need use bram and bram controller in my project to store the output of fft.
can any one tell how to use bram means how to use signal of bram ( din,dout,rnw,en)  in user_logic module to write the data into the memory.
it will be very usefull if anyone replies.
berufspenner
Are you sure the bram (block ram) is big enough for your purpose?
drjohnsmith
step back,
what tools you using.
 if you need a BRAM controler, that implies that you are using EDK.
If you using ISE, then you don't need a BRAM controler, just infer the RAM you require.
 This is taken from the Xilinx template file built into ISE.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity rams_04 is
    port (CLK : in std_logic;
          WE  : in std_logic;
          A   : in std_logic_vector(5 downto 0);
          DI  : in std_logic_vector(15 downto 0);
          DO  : out std_logic_vector(15 downto 0));
end rams_04;
architecture syn of rams_04 is
    type ram_type is array (63 downto 0) of std_logic_vector (15 downto 0);
    signal RAM : ram_type;
begin
    process (CLK)
    begin
        if (CLK'event and CLK = '1') then
            if (WE = '1') then
                RAM(conv_integer(A)) <= DI;
            end if;
        end if;
    end process;
    DO <= RAM(conv_integer(A));
end syn;
pavithra
hi thank u very much for reply. but i m using edk, previously i used fifo to store the output  in user_logic module of the custom ip but its not working properly. so i m planning use BRAM and xps_bram controler to store the output.but i dont no how to use the signals regarding memory in user_logic module.
please can u tell if u have some example code to write the output to memory.
drjohnsmith
my memory of EDK and BRAM.
You don't have to wire up anything.
  in the EDK, the BRAM controler is instantiated, along with the BRAM and wired up.
BRAM controler is only used for the Processor bus,
pavithra
hi sorry i didnt understand.
i have instantiated my vhdl module in user_logic module. the following like this
comprehensive_agu_map :comprehensive_agu
generic map (width=>width)
port map(sys_clk=> Bus2IP_Clk,
sys_clk_by2=> Bus2IP_Clk,
reset=>reset,
addr_mode=>"0111",
start=>sigstart,
addr_gen_en =>sigaddr_gen_en,
n=>"00000100",
l =>"00000100",
m=>"00001000",
eff_addr =>eff_addr_temp
so i want to store the output eff_addr_temp.(eff_addr_temp is signal) i want to see the output in terminal)
i hope u understand my problem. can u help me please.
i attached my user_logic here(i used fifo to store the output but its not working)
drjohnsmith
well I'm confused,
 If your using EDK, then you do not instantiate the BRAM controler, it's done in EDK.
If your doing your own VHDL that does not connect to the Porcessor bus, then  that is not in EDK, and you don't need the BRAM controler.
pavithra
hi i m attaching here my user_logic module.just i want to store the output and want to see in terminal.
drjohnsmith
Ok, so
Your in EDK.
 and you have imported your own peripheral ?
If you just need BRAM, why ?
  I'd have just instantiated a BRAM and controler fomr the Xilxin EDK tool directly, and it would have been wired in automaticaly to the PBL bus,
I get impresison you need to take step back, try re doing the EDK tutorial that clomes with Xilinx,
pavithra
hi i need one more clarification.
Is BRAM used only to store a software application (c program or input data from c program) or can it be used to store the output of any user defined peripheral.
eg, can i store the output of the instantiated VHDL program in user_logic module.
thank u
drjohnsmith
HI
which bus are you conecting the BRAM too ?
Which bus is your user logic conencting too ?
EDK is Bus based design.
pavithra
i connected bram to plb throghh bram controller
user_logic is connected to splb
drjohnsmith
sorry all I can say is I'm confused,
not much help I know, but sorry.
pavithra
hi sorry...... is i m wrong
ytian
In my design, BRAM is used to save some data that need deterministic access (comparing with DDR/DDR2 through MPMC -- the access time is not fixed, depending on the other ports are accessing or not).  To use BRAM in EDK is straight forward.  EDK provide BRAM with two port (A and B). PortA can be used for cpu access. PortB can be used for user logic to read/write user data. Since PortA is used for cpu access, it needs a bram controller (which connects to PortA in one side and PLB in the other side). Hope this helps.
Tom
pavithra
hi ytian thanku very much. can u tell me signals to use portB of BRAM regrding read/write user data.
golson
I would use this document.  And Create a IPIF to connect to the bus.    You may need to retime signals since the bus runs at a fast clock rate.
