hamze
software Optimization problem for a hardware on FSL bus
hi,
I have a hardware of Xilinx cores for type cast ( int 2 double ) on fsl bus,
I wrote a macro for it like below :
#define  fsl_fpui2d( a, c, cmd, status  );\
     write_into_fsl(    cmd                       , 0);\
     write_into_fsl(   a                             , 0);\
     read_from_fsl(*( (unsigned int *)(void *)(&c))     , 0);\
     read_from_fsl(*( (unsigned int *)(void *)(&c) + 1 ), 0);\
     read_from_fsl( status                               , 0);\
I used macro because function takes too time.
this code works OK ( so code is right )  when optimization of my code is OFF but whenever I turn it on it does not.
I am sure that this part of code cause the problem, because whenever I replace this macro with simple  c = (double) a  then every thing is ok with or without optimization.
I tried to put all above codes  ( both of write_into_fsl & read_into_fsl  are assembly code of put or get )  inside a  atomic  asm volotile ( ) but nothing changed.
I also tried to define every variable which replace 'c' ( becase it is a macro ) to be "volatile double" but still nothing changed.
now what should I do? what did optimization do to my code?
hamze
I could solve problem by exact debuging of assembly code with help of mb-objdum .
and this problem was really instructive for me.
my hardware core on fsl bus returns a double precision number.
for reading result I read it in two 32 bit number like this
and place it in a double type variable
by this type of reading result compiler could not understand the CHANGE of varialbe  c,
and this cause problem.
thanks
goran
Have you disassembled the elf file using mb-objdump and looked what the compiler generates?
Göran
hamze
thanks goran
I also debug assembly of my software in SDK but  I am not sure that the assembly which is shown in Optimized software is also optimized or not,  I will check ELF
but till now I found a solution for temporary solve problem,
I just insert some prints and some tempt varialbes to prevent compiler remove something,
like below code, I will inverstigate this code more to find the source of problem.
#define  fsl_fpu64( a,  b, c, cmd, status  );\
    volatile int c1, c2;\
    volatile int statusV;\
    printf("\n\r\n\r-- %d",  cmd   );\
    printf("-- %d", int(100 *a) );\
    printf("-- %d", int(100 *b) );\
    asm volatile( \
    "put\t%3,rfsl" stringify(0) "\n\t" \
    "put\t%4,rfsl" stringify(0) "\n\t" \
    "put\t%5,rfsl" stringify(0) "\n\t" \
    "put\t%6,rfsl" stringify(0) "\n\t" \
    "put\t%7,rfsl" stringify(0) "\n\t" \
    "get\t%0,rfsl" stringify(0) "\n\t" \
    "get\t%1,rfsl" stringify(0) "\n\t" \
    "get\t%2,rfsl" stringify(0) "\n\t" \
    : "=d"( c1  ), \
      "=d"( c2  ), \
      "=d"( statusV                                  )  \
    : "d"(  cmd                                      ), \
      "d"(*( (unsigned int *)(void *)(&a))           ), \
      "d"(*( ((unsigned int *)(void *)(&a)) + 1)  ), \
      "d"(*( (unsigned int *)(void *)(&b))          ), \
      "d"(*( ((unsigned int *)(void *)(&b)) + 1)  )\
      *( (unsigned int *)(void *)(&c)) = c1; \
      *( (unsigned int *)(void *)(&c) + 1 ) = c2; \
      status = statusV;\
     printf("-- %d", (int)( 100 *c) );\
     printf("-- %d", c1);\
     printf("-- %d", c2);\
     printf("-- %d", status);\
I should check ELF deeply, I will write conclusion here
regards,
hamze
thanks
