Visitor lxyer
some question about file system API
  When i building some program on standalone system, I encounter the same link error described in http://forums.xilinx.com/t5/EDK-and-Platform-Studio/Porting-source-code-to-SDK-linker-error/td-p/97526.
  But when i use those file api (fseek, fread, fopen etc )in a test program, as the Employee mentioned, it just pass the compile and generate elf file.
  I wonder if those api are just keep for completeness and do nothing just return 0. Could I find the source code for those function?
 If the standalone&xilfatfs do not support those function, could I redefine those function in lib?
Visitor lxyer
Re: some question about file system API
I have fixed the problem, it is indeed caused by some file APIs that donot support by the library. And my code works fine after I comment out one file API "rename".
Visitor lxyer
