nakanish
sprintf causes code to hang during simulation
When I try using the sprintf() function in my code the processor doesn't get past this command.  Here's the command I'm using...
while (format[percent_search] && arg_counter < MAX_ARGS)
    if (special_character)
      special_character = FALSE;
    else
      switch (format[percent_search])
        case '%':
          args[arg_counter++] = va_arg(arg_list, uint_32);
          break;
        case '\\':
          special_character = TRUE;
          break;
    }  /* if (special_character) */
    percent_search++;
  }  /* while */
  va_end(arg_list);
  /* Create final string to send  */
  sprintf(out_str, format, args[0],
                           args[1],
                           args[2],
                           args[3],
                           args[4],
                           args[5],
                           args[6],
                           args[7],
                           args[8],
                           args[9],
                           args[10]);
Has anyone out there had any problem with the sprintf() function?  Any ideas on what would cause this problem?
jasonjiang
I got the same issue.
You have to use Microblaze library, my_sprintf(), defined in xil_printf.c like below:
// This is the start of the file for other *printf functions
// that are used in the embedded system.  For some reason,
// the standard printf functions provided in the Xilinx
// library do not seem to work.
int my_sprintf(char *buff, char *fmt, ... )
    va_list ap;
    int     length;
    va_start(ap, fmt);
    length = xil_vsprintf(buff, fmt, ap);
    va_end(ap);
    return (length);
jasonjiang
    va_list ap;
    int     length;
    va_start(ap, fmt);
    va_end(ap);
    return (length);
