sw code in ddr
Hello.
I need to load my Application to DDR because BRAM is not enought. On my DDR I’ve got some data, that is directly addressed with addresses. I don’t know, where the loaded code is lying on my DDR. This is dangerous for my code and my other data.
Is there a possibility, that the code is loaded to a specific base_address to a hig_address in a DDR storage? Or how can I see, where the sw code is lying on my DDR?
Thanks for your help.
Best regards,
Michi
Re: sw code in ddr
Hello.
You can leave 1 MB of space for code execution from DDR starting from base address of DDR. It will be sufficient. Rest of the DDR you can use for your application.
Best of luck.
Unlimited in my Limits.
Re: sw code in ddr
Hello.
Best of luck.
Re: sw code in ddr
Thanks for your help ;-)
Best regards,
Michi
