sysproj argument is ignored when running library create in Vitis 2020.1
Running the command "library create -name foo_library -type static -platform myPlatformHw -domain myStandaloneDomain -sysproj mySysProj" doesn't seem to work.
What I expect is that a library gets created under mySysProj with the name "foo_library"
What happens is that a system project gets created with the name "foo_library_system" with a library project "foo_library" underneath it.
