trace c code in SDK
I need to compare two projects - both on microblaze.
How can I enable the trace to see what the c code is doing?
Thank you.
David.
Re: trace c code in SDK
Hi @davidfi1,
You can use TCF profiler, or gprof based profiling. Additionally, XSDB/XSCT support profile and trace for MB. Please see mbtrace and mbprofile commands
If you want to compare the code, you can use the following in eclipse, select the source directories that you want to compare with Ctrl Key, do right mouse button click and select Compare with -> Each Other menu item. Please let us know whether this works for you or this is what you are looking for
Raju
Thank you,
I was hoping to compare the flow of the code by comparing events used by the profiling tool.
Is this possiable?
Thank you again.
David.
Hi @davidfi1,
