typedef int (*func_ptr)(int c);
I have upgraded the hardware in my design and I therefore needed to get an updated bsp. (I've tried regenerating it but it didn't work!!) so I created a new one.  When I do so I get the following error. The only difference I can see between the 2 system.mss files is that the OS has changed from 4.2 to 5.1. Any suggestions as to how I fix this?
I don't get this error with the previous bsp. So clearly something has changed in the new bsp which is causing this error. The alternative is to upgrade the old bsp file. I have tried to do this (using regenerate bsp source) but the xparameters file isn't updated with the changes which I find odd. If I create a new bsp file the changes are made to the xparameter file but then I get the above error. This is a frustrating error as it appears to be a tools related bug and nothing to do with what I'm doing.
Re: typedef int (*func_ptr)(int c);
fixed this myself in the end. Well, it wasn't really a fix. I just didn't need this function so commented it out.
Scholar stephenm
In the warnings you can see that some of the header files have changed when porting.
Look at the line of code that is giving the error, and do a F3 and see is the error ligit.
You may need to change your application codeto reflect the changes in the BSP
When something strange happens, i recommend to reset output product of the block design and reset all runs, like the old ISE a good clean can be important!
