Visitor dragonbka
ucos iii bsp generate miss interrupts ID.
Hi everyone,
I am working at sdk 2017.4 and using repository ucos 1.43.
I have a hdf file and when i create app in standalone mode, the bsp gen file xparameter.h have the ID intr like this:
/* Definitions for Fabric interrupts connected to ps7_scugic_0 */
#define XPAR_FABRIC_ETH_BUFFER_RX_INTERRUPT_INTR 61U
#define XPAR_FABRIC_CDMA_PS_CDMA_INTROUT_INTR 62U
#define XPAR_FABRIC_ETH_BUFFER_TX_INTERRUPT_INTR 63U
/* Canonical definitions for Fabric interrupts connected to ps7_scugic_0 */
#define XPAR_FABRIC_LLFIFO_0_VEC_ID XPAR_FABRIC_ETH_BUFFER_RX_INTERRUPT_INTR
#define XPAR_FABRIC_AXICDMA_0_VEC_ID XPAR_FABRIC_CDMA_PS_CDMA_INTROUT_INTR
#define XPAR_FABRIC_LLFIFO_1_VEC_ID XPAR_FABRIC_ETH_BUFFER_TX_INTERRUPT_INTR
and it worked. But when i create app use Ucos, and in the ucos_bsp, file xparameter miss that interrupts ID. there is content in xparameter.h when i use Ucos.
#define XPAR_FABRIC_XLCONCAT_0_DOUT_INTR 61
Because dont have ID interrupts so i cant connect the interrupts with the handler function.
i try coping the ID from the standalone bsp to ucos bsp but it dont work.
Sorry about i am not good at english, and how to fix it? thanks so much.
Re: ucos iii bsp generate miss interrupts ID.
Hi @dragonbka
Could you provide more details about the ucos BSP repository you are using? where did you get that? From a quick view it seems that the xparameters.h file created by the ucos BSP is not able to detect that your interrupt signals are muxed with a concat as it just gives the number 61 to a concat block that is not really an IP per se.
Ibai
Ibai is correct here. For example if you have a look at the tcl code that is delivered with the BSP for the uc-os:
https://github.com/ggangliu/uC-OS-III/blob/master/Micrium_Xilinx_Repo_1_42/ucos_v1_42/ucos/drivers/ucos_scugic/data/xil_scugic.tcl
This will not get the vector places for each IP connected to the scugic via a CONCAT block. The latest tcl can be seen here:
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/scugic/data/scugic.tcl
So, a patch could be created with the updated scugic.tcl.
However, we would need to source for the BSP, and your HDF to test
Visitor dragonbka
Hi @Ibai, thanks for your reply, I’m using repository ucos 1.43 which download from micrium.com before the new version 1.44 update.
Can you share your HDF?
I tried this in the 1.44 version of the BSP from Micrium on a simple BD that has a concat:
I used the HSI to create the BSP:
The resultant xparameters is correct:
#define XPAR_FABRIC_AXI_GPIO_0_IP2INTC_IRPT_INTR 61U
#define XPAR_FABRIC_AXI_TIMER_0_INTERRUPT_INTR 62U
#define XPAR_FABRIC_GPIO_0_VEC_ID XPAR_FABRIC_AXI_GPIO_0_IP2INTC_IRPT_INTR
#define XPAR_FABRIC_UCOS_AXITIMER_0_VEC_ID XPAR_FABRIC_AXI_TIMER_0_INTERRUPT_INTR
Can you use the 1.44 version? If you are stuck in the 1.43 version then you could copy the utils for v1.44 here
Visitor dragonbka
hi @stephenm, thanks for ur help. the Ucos 1.44 require vivado 2018.3, however with some reason i cant use vivado 2018.3. I send you my hdf file, can you  check it with ucos repository 1.43, thanks so much.
can you pass me the link for 1.4.3? I only see 1.4.4 on micrium website.
If you cannot move to 1.4.4, then you can just copy (make a backup first) the two files below from 1.4.4 into 1.4.3
bsp/data/ucos_tcl_utils.tcl
bsp/data/xil_tcl_utils.tcl
Visitor dragonbka
Hi @stephenm , in micrium web only download the newest version ucos, the ucos 1.43 i downloaded long time ago before the newest version update. I try copy 2 file u said but it isn’t work, when create bsp by sdk to get the interrupts id  i have to change the driver ucos_scugic to scugic. But it build failed because cant include ucos_scugic.h. Can u guide me more detailed. Thanks so much
I cant really help without seeing the 1.4.3 version. Have you contacted Micrium on this issue?
