pkundara
ultra 96 v2 board not available in vivado
ultra96 v2 board is not available in vivado.
we have ultra96 v2 and in vivado it is showing v1.2 is this the correct version for v2 board?
we tried with that but board was not booted with that.
from when can i get example design?
hamza.bendaoudi
Hi @pkundara ,
You will need to download the Ultra96 v2 board definition files from here: https://github.com/Avnet/bdf
In the same link, it's explained how to add the board files to Vivado (copy the board files to /Xilinx/Vivado/201x.x/data/boards/board_files).
I think that the v1.2 you are seeing is the version of the board files (for ultra96 v1).
Good Luck!
Hamza
hamza.bendaoudi
Hi @pkundara ,
Good Luck!
Hamza
pkundara
solved the issue
