sai_shashi
unable to stop microblaze
Hi there,
I am using Virtex 7 board and i have developed a design with MicroBlaze and HLS IP core. Generated bitstream as well. But when i develop SDK app and run on the board, it gives me the following error: Can someone help me?
stephenm
Can you verify if your reset is set up correctly. I see you have the microblaze reset connected to proc reset mb_reset. But are you supplying a valid reset to the proc reset? If using a xilinx dev board you can double click on the proc reset block and choose the board reset here. This will create the correct pin constraint automatically. If you are using a custom board you will need to write the xdc manually
