Participant arda.shah
undefined reference to math functions in SDK 14.3
this code has a problem with undefined reference to `cosl' , `sinl' functions
Have an idea how to solve this problem?
Xilinx Software Development Kit  Release 14.3 Build SDK_P.40xd  under Win7 x64 with included math.h and with -O0 or -O3 optimization
/***************************** Include Files ********************************/
#include "xsysmon.h"
#include "xparameters.h"
#include "xstatus.h"
#include "xil_exception.h"
#include "sleep.h"
#include "stdio.h"
#include "math.h"
#include <stdlib.h>
#include "xscugic.h"
#include "xil_printf.h"
/************************** Constant Definitions ****************************/
 * The following constants map to the XPAR parameters created in the
 * xparameters.h file. They are defined here such that a user can easily
 * change all the needed parameters in one place.
#define SYSMON_DEVICE_ID	XPAR_SYSMON_0_DEVICE_ID
#ifdef XPAR_INTC_0_DEVICE_ID	/* Interrupt Controller */
#define INTC_DEVICE_ID		XPAR_INTC_0_DEVICE_ID
#define INTR_ID			XPAR_INTC_0_SYSMON_0_VEC_ID
#else	/* SCUGIC Interrupt Controller */
#define INTC_DEVICE_ID		XPAR_SCUGIC_SINGLE_DEVICE_ID
#define INTR_ID			XPAR_FABRIC_SYSMON_0_VEC_ID
#endif /* XPAR_INTC_0_DEVICE_ID */
#define INTC			XIntc
#define INTC_HANDLER		XIntc_InterruptHandler
#define INTC			XScuGic
#define INTC_HANDLER		XScuGic_InterruptHandler
/**************************** Type Definitions ******************************/
/***************** Macros (Inline Functions) Definitions ********************/
/************************** Function Prototypes *****************************/
static int SysMonSingleChannelIntrExample4(INTC* IntcInstPtr,
			XSysMon* SysMonInstPtr,
			u16 SysMonDeviceId,
			u16 SysMonIntrId);
static void SysMonInterruptHandler(void *CallBackRef);
static int SysMonSetupInterruptSystem(INTC* IntcInstPtr,
				      XSysMon *SysMonPtr,
				      u16 IntrId );
static int SysMonFractionToInt(float FloatNum);
/************************** Variable Definitions ****************************/
static XSysMon SysMonInst; 	  /* System Monitor driver instance */
//static XIntc InterruptController; /* Instance of the XIntc driver. */
static INTC IntcInst; 		/* Instance of the XIntc driver */
 * Shared variables used to test the callbacks.
volatile static int EocFlag = FALSE;	  	/* EOC interrupt */
volatile static int VccintIntr = FALSE;	  	/* VCCINT alarm interrupt */
* Main function that invokes the Single Channel Interrupt example.
* @param	None.
* @return
*		- XST_SUCCESS if the example has completed successfully.
*		- XST_FAILURE if the example has failed.
* @note		None.
int SysMonSingleChannelIntr4(void)
	int Status;
    xil_printf("\n\r**SysMonSingleChannelIntrExample Test**\n\r");
	 * Run the SysMonitor interrupt example, specify the parameters that
	 * are generated in xparameters.h.
	Status = SysMonSingleChannelIntrExample4
				   (&IntcInst,
				   &SysMonInst,
				   SYSMON_DEVICE_ID,
				   INTR_ID);
	if (Status != XST_SUCCESS) {
//		xil_printf("SysMonSingleChannelIntrExample Test FAILED\r\n");
		return XST_FAILURE;
//	xil_printf("Successfully run SysMonSingleChannelIntrExample Test\r\n");
	return XST_SUCCESS;
* This function runs a test on the System Monitor/ADC device using the
* driver APIs.
* The function does the following tasks:
*	- Initiate the System Monitor/ADC device driver instance
*	- Run self-test on the device
*	- Reset the device
*	- Set up alarm for VCCINT
*	- Set up the configuration registers for single channel continuous mode
*	for VCCINT channel
*	- Setup interrupt system
*	- Enable interrupts
*	- Wait until the VCCINT alarm interrupt occurs
* @param	IntcInstancePtr is a pointer to the Interrupt Controller
*		driver Instance.
* @param	SysMonInstPtr is a pointer to the XSysMon driver Instance.
* @param	SysMonDeviceId is the XPAR_<SYSMON_ADC_instance>_DEVICE_ID value
*		from xparameters.h.
* @param	SysMonIntrId is
*		XPAR_<INTC_instance>_<SYSMON_ADC_instance>_VEC_ID
*		value from xparameters.h
* @return
* @note		This function may never return if no interrupt occurs.
					u16 SysMonDeviceId,
					u16 SysMonIntrId)
	long double Y[256];
	long double Y_s[256][128];
	long double Y_c[256][128];
//	long double Sum_ampl[128];
	long double SUM_1_real[128]={0.0},SUM_1_image[128]={0.0};
	long double A[128], B[128], C[128];
	int Status, i, n, m, N=256;
	XSysMon_Config *ConfigPtr;
	u16 VPVNData,
//	VPVNDataTR,
	Matr[256], Sum, Matr_1[256];
	u32 IntrStatus;
//	float Y[256];
	 * Initialize the SysMon driver. w/ XSysMon_Reset
	ConfigPtr = XSysMon_LookupConfig(SysMonDeviceId);
	if (ConfigPtr == NULL) {
		return XST_FAILURE;
	XSysMon_CfgInitialize(SysMonInstPtr, ConfigPtr, ConfigPtr->BaseAddress);
	 * Self Test the System Monitor/ADC device. w/ 2 x XSysMon_Reset
	Status = XSysMon_SelfTest(SysMonInstPtr);
		xil_printf("XSysMon_SelfTest failed\r\n");
		return XST_FAILURE;
	 * TODO Set the ADCCLK frequency equal to 1/32 of
	 * System clock for the System
	 * Monitor/ADC in the Configuration Register 2.
	 * Desired ADC Sample Rate when Clock divider=4 is 961,54 KS/sec
	 * div 5=769,23 KS/sec
	 * div 6=641,03 KS/sec
	 * div 8=480,77 KS/sec
	 * div 16=240,38 KS/sec
	XSysMon_SetAdcClkDivisor(SysMonInstPtr, 4);
	 * TODO Set the sequencer in Single channel mode.
	XSysMon_SetSequencerMode(SysMonInstPtr, XSM_SEQ_MODE_SINGCHAN);
	 * TODO Set the configuration registers for single channel continuous mode
	 * of operation for the VPVN channel and Differential (Bipolar) mode.
	Status=  XSysMon_SetSingleChParams(SysMonInstPtr, XSM_CH_VPVN,
						FALSE, FALSE, TRUE);
	if(Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * Disable all the alarms in the Configuration Register 1.
	XSysMon_SetAlarmEnables(SysMonInstPtr, 0x0);
	 * Set up Alarm threshold registers for the VCCINT
	 * High limit and lower limit so that the alarm does not occur.
	XSysMon_SetAlarmThreshold(SysMonInstPtr, XSM_ATR_VCCINT_UPPER, 0xFFFF);
	XSysMon_SetAlarmThreshold(SysMonInstPtr, XSM_ATR_VCCINT_LOWER, 0x0);
	 * Setup the interrupt system.
	Status = SysMonSetupInterruptSystem(IntcInstPtr,
					    SysMonInstPtr,
					    SysMonIntrId);
		return XST_FAILURE;
	 * Clear any bits set in the Interrupt Status Register.
	IntrStatus = XSysMon_IntrGetStatus(SysMonInstPtr);
	XSysMon_IntrClear(SysMonInstPtr, IntrStatus);
	 * Enable EOC interrupt.
	XSysMon_IntrEnable(SysMonInstPtr, XSM_IPIXR_EOC_MASK);
	 * Enable global interrupt of System Monitor.
	XSysMon_IntrGlobalEnable(SysMonInstPtr);
	for (i=0; i<=255; i++)
	 * Wait till the End of Conversion occurs.
	EocFlag = FALSE; 		/* Clear the EOC Flag */
	while (EocFlag != TRUE);
//	for (i=0; i<=255; i++)
	* Read the ADC converted Data from the data registers for VPVN.
	* MAX DATA IN UNIPOLAR MODE IS FFF=1VOLT
	VPVNData = XSysMon_GetAdcData(SysMonInstPtr, XSM_CH_VPVN);
//	if (i == 0) xil_printf("\rThe 1th ADC VPVN Data=0x%x.\r\n",(VPVNData));
//	if (i == 10) xil_printf("\rThe 10th ADC VPVN Data=0x%x.\r\n",(VPVNData));
	Matr_1[i] = VPVNData;
//	VPVNDataTR = VPVNData >> 4;
	  for(n=0;n<=255;n++)
	   Matr[n]=Matr_1[n]>>4;
	   if((Matr[n]>=0x0)&&(Matr[n]<=0x7FF))
	   Y[n]=Matr[n];
	   if((Matr[n]>=0x800)&&(Matr[n]<=0xFFF))
	     Y[n]=0xFFF-Matr[n];
	     Y[n]=-Y[n];
	for (i=0; i<=255; i++){
			printf("\rThe Current Matr 0x%x.\r\n",(Matr[i]));
	xil_printf("\r------------------------------------------------\r\n");
	for (n=0; n<=255; n++){
		//printf("\rThe Current trans %03d\r\n", SysMonFractionToInt(Y[n]));
		printf("\rThe Current trans %Lf\r\n", Y[n]);
	//TODO FFT
//	 m=N/2;
	 for(n=0;n<=N-1;n++)
	   Y[n]=sinl(2*M_PI*n/N);
	   for(m=0;m<=N/2-1;m++)
	     Y_s[n][m]=sinl(2*M_PI*n*m/N);
	     Y_c[n][m]=cosl(2*M_PI*n*m/N);
//	fun_my();
	  for(n=0;n<=N-1;n++)
	     SUM_1_real[m]=SUM_1_real[m]+Y[n]*Y_c[n][m];
	     SUM_1_image[m]=SUM_1_image[m]+Y[n]*Y_s[n][m];
		for (n=0; n<=127; n++){
			A[n] = SUM_1_real[n]*SUM_1_real[n];
			B[n] = SUM_1_image[n]*SUM_1_image[n];
			C[n] = A[n] + B[n];
			printf("\rThe amplitude is %d, %Lf\r\n", n, C[n]);
	XSysMon_IntrGlobalDisable(SysMonInstPtr);
	return XST_SUCCESS;
* This function is the Interrupt Service Routine for the System Monitor device.
* It will be called by the processor whenever an interrupt is asserted
* by the device.
* There are 8 different interrupt types supported
*	- Over Temperature
*	- ALARM 0
*	- ALARM 1
*	- ALARM 2
*	- End of Sequence
*	- End of Conversion
*	- Over Temperature DeActivated
*	- ALARM 0 DeActivated
* This function only handles the EOC interrupt and ALARM 1 interrupt.
* User of this code should modify the code to meet needs of the application.
* @param	CallBackRef is the callback reference passed from the Interrupt
*		controller driver, which in our case is a pointer to the
*		driver instance.
* @return	None.
* @note		This function is called within interrupt context.
	u32 IntrStatusValue;
	XSysMon *SysMonPtr = (XSysMon *)CallBackRef;
	 * Get the interrupt status from the device and check the value.
	IntrStatusValue = XSysMon_IntrGetStatus(SysMonPtr);
	if (IntrStatusValue & XSM_IPIXR_EOC_MASK) {
		 * Set End of Conversion  interrupt flag so the code
		 * in application context can be aware of this interrupt.
		EocFlag = TRUE;
		XSysMon_GetStatus(SysMonPtr); /* Clear the latched status */
	if (IntrStatusValue & XSM_IPIXR_VCCINT_MASK) {
		 * Set VCCINT interrupt flag so the code in application context
		 * can be aware of this interrupt.
		VccintIntr = TRUE;
	 * Clear all bits in Interrupt Status Register.
	XSysMon_IntrClear(SysMonPtr, IntrStatusValue);
* This function sets up the interrupt system so interrupts can occur for the
* System Monitor/ADC.  The function is application-specific since the actual
* system may or may not have an interrupt controller. The System Monitor/ADC
* device could be directly connected to a processor without an interrupt
* controller. The user should modify this function to fit the application.
*		driver Instance
* @param	SysMonPtr is a pointer to the driver instance for the System
* 		Monitor device which is going to be connected to the interrupt
*		controller
* @param	IntrId is XPAR_<INTC_instance>_<SYSMON_ADC_instance>_VEC_ID
* @return	XST_SUCCESS if successful, or XST_FAILURE.
* @note		None.
				      XSysMon *SysMonPtr,
				      u16 IntrId )
	int Status;
	XScuGic_Config *IntcConfig;
	 * Initialize the interrupt controller driver so that it is ready to
	 * use.
	IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
	if (NULL == IntcConfig) {
		return XST_FAILURE;
	Status = XScuGic_CfgInitialize(IntcInstPtr, IntcConfig,
					IntcConfig->CpuBaseAddress);
		return XST_FAILURE;
	XScuGic_SetPriorityTriggerType(IntcInstPtr, IntrId, 0xA0, 0x3);
	 * Connect the interrupt handler that will be called when an
	 * interrupt occurs for the device.
	Status = XScuGic_Connect(IntcInstPtr, IntrId,
				 (Xil_ExceptionHandler)SysMonInterruptHandler,
				 SysMonPtr);
		return Status;
	 * Enable the interrupt for the System Monitor/ADC device
	XScuGic_Enable(IntcInstPtr, IntrId);
	 * Initialize the exception table.
	Xil_ExceptionInit();
	 * Register the interrupt controller handler with the exception table.
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
				(Xil_ExceptionHandler) INTC_HANDLER,
				IntcInstPtr);
	 * Enable exceptions.
	Xil_ExceptionEnable();
	return XST_SUCCESS;
* This function converts the fraction part of the given floating point number
* (after the decimal point)to an integer.
* @param	FloatNum is the floating point number.
* @return	Integer number to a precision of 3 digits.
* @note
* This function is used in the printing of floating point data to a STDIO
* device using the xil_printf function. The xil_printf is a very small
* foot-print printf function and does not support the printing of floating
* point numbers.
	float Temp;
	Temp = FloatNum;
	if (FloatNum < 0) {
		Temp = -(FloatNum);
	return( ((int)((Temp -(float)((int)Temp)) * (1000.0f))));
Re: undefined reference to math functions in SDK 14.3
compiled if you use g++ compiler instead gcc
please help, the project is not compiled with this error
Scholar stephenm
Thanks, stephenm for help!
