unreadable characters in the SDK console window
I am new to the SDK, I am trying to run a simple c=a*b (by modifying the hello world template) on the MicroBlaze core and the console window of SDK show me a very strange result.
Could anyone tell me why?
Best wishes,
Lei
Re: unreadable characters in the SDK console window
The problem was that I used the "print" function is the SDK. It was solved by using the "xil_printf" function.
That looks like a baud rate issue. Make sure the settings in the microblaze match the configuration in the sdk.
@dcwhitehead Hi,
Thanks for the reply.
I just checked my design. I think they are the same.
Lei
