slims
unresolved inclusion "xtmrctr.h"
I'm using edk 14.6,I need to use timer in my C program.When I  include  "xtmrctr.h"
I got this error:
bwiec
Is there an instance of the AXI Timer/Counter in your hardware? If so, do you see the folder for its driver in your BSP?
www.xilinx.com
bwiec
www.xilinx.com
puja
Dear Sir,
There is an instanc of AXI timer in my design , but I am facing the same issue. xtmrctr.h is not found.
Please help.
Puja Kumari
