bhavanithya
update_mem failed, Unknown Exception
Hello all,
I designed a simple BRAM with a Zynq processor.
Address range for bmg is,
0x00_A000_0000 to 0x00_A03F_FFFF (4M)
Device: zcu111 ultrascale device.
data1.mem file,
@A0000000 DE412345
I ran my update mem script and I got the following output,
****** updatemem v2018.3.1 (64-bit)
  **** SW Build 2489853 on Tue Mar 26 04:20:25 MDT 2019
  **** IP Build 2486929 on Tue Mar 26 06:44:21 MDT 2019
    ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
source D:/Xilinx/Vivado/2018.3/scripts/updatemem/main.tcl -notrace
Command: update_mem -meminfo ./module1_wrapper1.mmi -data ./data1.mem -proc module1_i/zynq_ultra_ps_e_0 -bit ./Zynq_BRAM1.runs/impl_1/module1_wrapper.bit -out ./download2.bit -force -debug
0 Infos, 0 Warnings, 0 Critical Warnings and 1 Errors encountered.
update_mem failed
Unknown exception
INFO: [Common 17-206] Exiting updatemem at Mon Oct 14 13:57:28 2019...
debug option does not help much. I have no idea why the exception is caused. I attached the mmi file (in xml because it is throwing some error when I upload as mmi file). Please take a look. Any lead is appreciated.
Note: I tried a similar design in Microblaze, the updatemem worked. I wrote the mmi file for my zynq design manually referring the mmi file created for the microblaze design. I also attached the tcl script I used to generate the mmi file
Bhavanithya Thiraviaraja
Please Kudo or Accept as a solution, if this post helped you.
Tags (2)
bhavanithya
Yes it is 4MB which is quite big. I wanted to use DDR but BRAM was more simple for now.
Address range in the address editor is 0x00_A000_0000 to 0x00_A03F_FFFF. And in the mmi file
 <AddressSpace Name="module1_i_zynq_ultra_ps_e_0.module1_i_axi_bram_ctrl_0" Begin="0" End="4194303">
I changed the address in the mem file to @00000000 instead of @A0000000 (taken from the address editor), and now I am able to see the dumped strings... and also the data in the memory @A0000000 in SDK
bhavanithya
I added the following lines at the end of the mmi file,
  <DRC>
    <Rule Name="RDADDRCHANGE" Val="false"/>
  </DRC>
as i found this in the sample mmi file provided in Xilinx Confluence page, the updatemem ran successfully but did not show any init_strings and the bit file is the same. What does this mean?
stephenm
Your BRAM looks quite big. What address range did you specify here?
bhavanithya
