jack.roundhouse
usage of tcl commands with xsct
hello,
In UG1208, there is a tcl command:
version
I saved this line to a tcl file then run it wiht
xsct xsct_script.tcl
It returns:
opening XSCT project ...
invalid command name "::xsdb::get_version"
    while executing
    (procedure "version" line 20)
    invoked from within
"version"
    (file "xsct_script.tcl" line 1)
How do I use this command properly?
XSCT version: 2017.4
OS: Linux Ubuntu 16.04
glena
That looks like a bug in 2017.4 - 2018.2   I do get the expected output running non-interactive on 2018.3.   This is the script I used:
set result [version]
puts $result
glena
puts $result
jack.roundhouse
@glena,
It definetely is. I used your very same script in 2017.4 and receive the before mentioned error.
Glad it has been fixed in the latest release.
Thank you
