usb-uart connection fails with ZC702 board SDK terminal
I am following the example project: Running the "Hello World " Application  as outlined in UG1165.   Everything works as expected with building the hardware and exporting to SDK.   I do all of the following as instructed in the document:
  Connect the USB cable from J17 (USB UART) to my PC
  Ensure SW10 settings are Bit-1 is 0 , Bit-2 is 1 (To select USB-UART).
 Configuartion options swithc SW16 is set for JTAG  (00000).
  Power up the board and open the SDK project file I previously created.
  Open the serial comm utilility and set it up for Conn Type = Serial, Port = COM3, Baud Rate = 115200, 8 Data,1 Stop, Parity = none.
Select File > New> Application Project using the Hello World Template.
Next SDK creates the application project and the bsp , and compiles and creates the ELF file.
Next...In the Project Explore Window I right click on hello_world and select Run as > Run Configurations.  Right click Xilinx C/C++ application(GDB) and click New
Now...When I click RUN in the Run Configuration window (according to the tutorial) a  message should appear asking if I want to launch the application even though configuration of the FPGA is not done.  BUT instead I get the ERROR shown in my screen capture below.
Note ***  IF I change the Config options SW16 to QUAD SPI Mode and use TERA TERM for the serial port connection then the USB -UART Connection works fine !  So I know its not a cable problem or SW10 settings problem. ???
Would really like to know what is happening here ? Why is SDK not able to make this serial port connection using its own serial communication utility ???
Thanks everyone.
Community Manager
Community Manager
Re: usb-uart connection fails with ZC702 board SDK terminal
In step#2, it asks you to connect digilent cable (JTAG cable) to the board. The commands you send from SDK to ZC702 are through the JTAG cable. So, you must need a JTAG cable to run these tests.
Scholar sampatd
Try to run using system debugger instead of the GDB debugger. To execute the application using System debugger, you can follow the steps described in the link below:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/SDK_Doc/SDK_tasks/sdk_t_tcf_standalone_app_debug_tcf.html
Community Manager
Community Manager
From SW10 settings, it looks like you are using Digilent USB-JTAG cable. To make sure that the JTAG connection is up, please open XMD and type- "connect arm hw" command. This will let us know if the cable is connected to the board properly or not.
hi,
a quick typo in the question you have. SW10 is relating to usb-jtag. if you are trying to use usb-jtag you should set the SW10 to "01" and use the digilent usb cable.
once this is set,
can you simply turn-on the board
launch XMD shell
type the command "connect arm hw"
what does the xmd console say here?
--hs
Hi Sampatd,
     Running as System Debugger gives me hello world on the SDK Terminal.  However this requires a JTAG cable connected to the board.  The tutorial I am following is to demonstrate "Hello World" with no bitstream and the board connected only using the USB-UART port  (J17).  I still don't understand why it did not work according to the tutorial document UG1165 ?
Hi smarell,
   If I connect a JTAG cable and run the command in XMD It indicates the JTAG chain is detected.   I am able to get hello world on the SDK terminal (with the JTAG cable connected) when I run as system debugger as suggested by Sampatd.  But this was not the intent of the Tutorial I am following  (UG1165  pages 26 - 29).  My understanding is that I should see hello world on the SDK Terminal with just the USB-UART port cable connected to my PC.   Am I missing something ?
Community Manager
Community Manager
Thank you Smarell !  Totally missed it . :)
