use lamb if contrlr as slave ip
I want access a block ram which is not local. I am using lmb if cntrlr as slave ip which is giving the controll signal to that block ram. Now inside my inetrface I have few ports inside of my ip which come from plv slave singale ip
Bus2IP_Clk
      Bus2IP_Reset
      IP2Bus_Data
      IP2Bus_WrAck
      IP2Bus_RdAck
      IP2Bus_Error
      Bus2IP_Addr
      Bus2IP_Data
      Bus2IP_RNW
      Bus2IP_BE
      Bus2IP_CS
      Bus2IP_RdCE
      Bus2IP_WrCE
I need to connect it woth lmb if cntrlr. Is it possible to map them? I am confused about    IP2Bus_WrAck,      IP2Bus_RdAck   signal
Anonymous
Not applicable
I would recommend that you use the external memory controller.
Anonymous
Not applicable
thanku for reply
