Visitor aminb
using single port rom in EDK
Hi all
in ise we use CoreGen to add single port rom and specify a coe file as initial data to the created single port rom then we portmap it and use it.
I want to integrate microblaze and VHDL together in xps.
I created a project in xps using bsb.
then I created a custom peripheral to add my VHDL code using this peripheral(by adding my code instance to user logic).
now I want use from a single port rom in my VHDL because I have so many initial data for process.
can anyone help me plz?
Re: using single port rom in EDK
You can use coregen to generate the ngc core.
When importing your IP to the design with CIP Wizard, select the ngc netlist file. CIP wizard will copy this ngc to pcore/<your IP>/netlists directory and create a bbd file in data directory.
You can refer to psf_rm.pdf in EDK/doc directory for the syntax of BBD file.
