arthes
vga interface
can anyone plz suggest me a good referrence or starter guide for vga interface...
thanks in advance...
ninjamafiakhan3
Hi!
You might like this tutorial that I have attached...or you can just google "VGA timing" or "VGA standard". Also you might like this link
http://www.fpga4fun.com/PongGame.html
mariano_severi
an IP core, named xps_tft, is included in EDK. You can have a look at the user guide of the ML403 or Spartan-3AN Starter Kit to find how to interface an external DAC or simply use external resistors. An open-source core can be found at www.opencores.org; look for VGA/LCD controller.
 Mariano
ninjamafiakhan3
Hi!
gszakacs
Professor
Professor
Here's another good resource.  It gives you the pixel clock
counts for timing of various VESA standard.  It also lets
you calculate custom timing based on your own parameters
Video Timing Calculator
Good luck,
Gabor
-- Gabor
