xiaolin
vivado 2015.1 install hangs at creating registry entries on windows 7.
I uninstall the vivado for some reasons.When I reinstall  the vivado,the problem occures .Even if I reinstall the os system ,it still does not work.
I also try most things on this answer that I was hopeful on, but no luck: http://www.xilinx.com/support/answers/60118.html.
Any help or leads would be greatly appreciated!
Thank you anyway.
anunesgu
Hi @xiaolin,
I'm sorry you didn't get an answer for this before.
I just had that exactly same issue while installing Vivado 2017.4 on Windows 7 (the installation wouldn't pass the creating registry entries).
All I had to do was run the installer as Admin (right click and select Run as Administrator) and all installed just fine.
Hopefully that works for you.
Andre Guerrero
Product Applications Engineer
anunesgu
Hi @xiaolin,
Andre Guerrero
