vivado 2018.3 and vivado 2018.2 have version conflict problem?
xinlix have version conflict problem? i am using 2019.2, and i am going to install in 2018.2, all in C disk. Will it have problems
Hi @andy_zhang Having multiple Vivado/Vitis versions installed is typical, and should not cause a problem. I would make sure though that you are not using multiple versions in the same project, or do not use the same workspace for multiple versions.
