weird problem in XPS 13.3
I have a microblaze system on a custom board, and it works, I can configure, compile software, run "hello world" type programs with a very basic implementation.  But I am trying to add more peripherals, and XPS is presenting me with a weird problem: when I add any peripheral which has a clock input, and I try to connect it (on the "Ports" tab), I'm not allowed to.  I right-click the port, and select "make new connection", and the connection name remains blank, then XPS errors out because of the unconnected clock.  This happens even with the simplest clocked IP, "utility_flipflop".  I can select connections for the other ports, like D, Q, etc.
Seems like just a GUI setting or something, but I can't figure it out.
Thanks for any help.
Rick
Re: weird problem in XPS 13.3
13.4 fixed it.
Rick
Can you make sure that the clocks filter box is ticked on the right hand side in XPS. You may have to drop down the filters tab, depending on the XPS verison.
Once you can see all the clocks, you should be able either make them external, or create a new conection, or connect them to an exisiting signal
Hi, thanks for the reply.
The CLOCKS filter is checked; I can see all the clocks, I can right-click and select "New Connection", but the new connection does not appear.  XPS thinks the clock line is connected, though, because when I untick the "Connected" filter, that clock signal disappears.  But I can't connect the connection to anything else, because it is unnamed.  And so PlatGen errors out.
I've successfully added peripherals before, and connected clocks, to other projects.  Just can't do it now.
I'm installing 13.4 now.
Rick
13.4 fixed it.
Rick
Participant peter.lieber
This is a really old thread, but I see this issue again in ISE 14.5.  Anybody know of a solution?
Its weird, because on the linux version in 14.4, it works, but it is a very weird UI design. I wonder if the selector is just not popping up in windows due to a Java version difference?
Ok, this morning when I started my computer, opened XPS, the GUI worked!  I have no idea what changed. Magically fixed bugs are worse than unfixed bugs in my mind... I will never know if it will one day stop working...
