gaze
xc2vp30 not found?
In the dialog box to select which family, size, and package the working FPGA is, the only ones listed for virtex2p are xc2vp2, xc2vp4, etc. I'm using the xilinx university board which has an xc2vp30, which isn't listed. What should I do?
xiaofeip
Are you using the ISE WebPack? Please note that 2VP30 might not be supported by WebPack that you are using.
--Xiaofei
barriet
gaze,
As Xiaofei stated, it sounds like you have ISE WebPACK (free download) instead of ISE Foundation.
You have several options:
-download a 60 day ISE Foundation evaluation:
-purchase ISE Foundation from a Xilinx distributor:
http://www.xilinx.com/company/sales/ww_disti.htm
-If you are a memory of an academic institution, check to see if they are a member of the Xilinx University Program:
http://www.xilinx.com/univ/
If so, they may already have purchased discounted ISE Foundation software for you to use.
Cheers,
bt
