Visitor frankzhao92
xfopencv make error using 2018.2 petalinux
I am having trouble compiling xfopencv examples using petalinux 2018.2 on ubuntu 14.04 machine. Here are the errors I get when I run make:
aarch64-linux-gnu-g++ -E -I. -I/usr/include -I../../include -O0 -Wall -DHLS_NO_XIL_FPO_LIB -mstrict-align -D __SDSCC__ -I /opt/Xilinx/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I /opt/Xilinx/Vivado/2018.2/include /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_image_accel.cpp -o /home/sftdev/xfopencv/examples/accumulate/_sds/.pp/xf_accumulate_image_accel.iix
In file included from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/cstdlib:75:0,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/ext/string_conversions.h:41,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/basic_string.h:6349,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/string:52,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/locale_classes.h:40,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/ios_base.h:41,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/ios:42,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/ostream:38,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/iostream:39,
from /opt/Xilinx/Vivado/2018.2/include/hls_stream.h:80,
from /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_config.h:34,
from /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_image_accel.cpp:31:
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/stdlib.h:131:36: error: missing binary operator before token "("
#if __HAVE_FLOAT128 && __GLIBC_USE (IEC_60559_TYPES_EXT)
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/stdlib.h:174:17: error: missing binary operator before token "("
#if __GLIBC_USE (IEC_60559_BFP_EXT)
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/stdlib.h:188:36: error: missing binary operator before token "("
In file included from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/cmath:45:0,
from /opt/Xilinx/Vivado/2018.2/include/hls_half.h:32,
from /opt/Xilinx/Vivado/2018.2/include/ap_int_sim.h:73,
from /opt/Xilinx/Vivado/2018.2/include/ap_int.h:65,
from /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_config.h:35,
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:44:36: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:59:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:67:36: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:137:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:169:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:488:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:835:17: error: missing binary operator before token "("
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++ -E -I. -I/usr/include -I../../include -O0 -Wall -DHLS_NO_XIL_FPO_LIB -mstrict-align -D __SDSCC__ -I /opt/Xilinx/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I /opt/Xilinx/Vivado/2018.2/include /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_image_accel.cpp -o /home/sftdev/xfopencv/examples/accumulate/_sds/.pp/xf_accumulate_image_accel.iix'
sds++ log file saved as /home/sftdev/xfopencv/examples/accumulate/_sds/reports/sds_xf_accumulate_image_accel.log
ERROR: [SdsCompiler 83-5004] Build failed
If I use 2017.4 petalinux, the xfopencv compiles successfully. Also to note, the hardware synthesis and build works on both 2017.4 and 2018.2.
Thanks in advance.
Visitor frankzhao92
Re: xfopencv make error using 2018.2 petalinux
Sorry I made a mistake with the post, it should be 2018.2 SDK, not petalinux. Please close this thread, I will make a new one.
Hi @frankzhao92,
We do not close threads :) Please just post a message with the link to the new thread and mark it as solution.
Ibai
Ibai
