xil_io.h: No such file or directory
  Hello,when i compile my code with xilinix SDK i get this error:
../src/helloworld.c:4:20: fatal error: xil_io.h: No such file or directory
Hi aichamb,
Please if you want people to contribute to your post and help with your question you need to provide more details.
Like the SDK release you are using, details about the applications (template, custom ....) and any step/configuration you made within your project.
Ibai
thank you @ibaie  i get the code from this : https://github.com/venkatesh20/SVM and i try to implement this code in FPGA : this code is created by vivado 2015.1 : the errors i got are :
