xil_printf not working
I'm encountering some odd behaviour.
I have programmed the Zynq FPGA using the Xilinx SDK (2014.4). I then run  a programme that I know works. It has now stopped outputting any text using xil_printf command to the com port. I'm using a Zedboard and this has an Led which lights when anything is output to com port and it doesn't light at all now. I know the program is running as I can see the main leds on the Zedboard are changing. I've seen posts that say I should increase the stack & heap size. This I've done in the lscript.ld file but still don't get any output. So it apears the problem is on the board. Any suggestions please?
Peter
Re: xil_printf not working
hi,
yes you can edit the MSS or when configuring the BSP select the drop-down to target ps7_uart.
--hem
hi,
have you run any other example available at http://zedboard.org/support/trainings-and-videos to confirm if board is functional?
--hem
Yes, I can switch from one version that works to this version that doesn't. The only change I'm making is to create another app & bsp. The app is identical. So the change has to be in the bsp.
I have encountered this problem before and it always comes after I've got a system that works and I want to make changes to it in the hardware ie I want to add another IP block. When I then open up the SDK I battle with getting it to recognise the new hardware. The best way I've found it to create a new bsp and app and copy the old app into the new. However when I do this I've quite often seen the xil_printf function stop working.
hi,
can you do a quick difference between the MSS of both BSP's. that might give a clue
--hem
How do you suggest I do a quick difference between the MSS of both BSP's?
hi,
since the issue is likely around the stdin/stdout, i would suggest you take both the MSS files and use a text editor for a quick comparison. you can focus on the Standalone BSP and the UART section of both MSS files
--hem
I've attached the 2 mss files. I'm not too sure what I'm looking for. The first one belongs to the systems that is failing. The 2nd is ok.
hi
i have looked at both the MSS files. And it looks that one of the MSS has UART16550(IP in PL) configured for Stdin/Stdout.
The other one is having PS_UART. If you dont have a UART16550 configured in PL, you need to change the stdin/stdout to ps7-uart to see the display.
refer to the snapshot attached.
--hem
@htsvn sorry for slow response. I got diverted onto another job and I've just got back to this one. What you say is exactly what has happened. However I find this to be odd behaviour. I add an extra UART port and what Vivado does is switch the text output from the exiting uart to the new uart. I don't understand why it has done that? At no point did I ask it to do that. So although you have correctly identified the problem what hasn't been explained is why it has changed from one port to the other?
Also how do I switch it back to how it was? Can I edit the MSS file?
hi,
--hem
