xil_printf
Hello. It seems that in new release of software several functions have been removed from library such as xil_printf(), putnum() and print(). Can anyone answer me why?
which version???
14.1
have you executed these functions in your code?is there any error?
If you did not get any error msg then there must be some other problems. you can try sendbyte function
Hy!
I just (today) updated from 13.4 to 14.1 and I can confirm the same "dissapear" of these functions. Same program yesterday was compiled succesfully today results in
error: ‘xil_printf’ was not declared in this scope
I had to manually edit stdio.h to obtain this functions, i.e. in object file this function exist, but do not declared in header.
Could you please paste here "your" declaration of xil_printf into stdio.h (and also that where did you put it)?
void _EXFUN(xil_printf, (const char*, ...));
void _EXFUN(putnum, (unsigned int ));
void _EXFUN(print, (char* ));
Ok, so I can confirm that it's "only" the stdio.h" which lacks of the declaration of the xil_printf function
A possible workaround for this is to paste the line
into the stdio.h file.
Hi guys,
As you have noticed the xil_printf(), putnum() and print() have been removed from the stdio.h header file and this is why you are getting the error. Howver they have been added to another header file and if you created a new simple project in v14.1 of the tools you can verify this with a simple helloworld example using xil_printf(), putnum() and print().
I am currently looking for the header file that store these declarations in v14.1 of the tools and I will update this post when I have found it.
Kind regards,
Gareth
I did a search on all *.h files in EDK 14.1. Those definitions are now in the powerpc stio.h files only. I wonder what good reason could have been to remove them from microblaze and arm stdio.h.
A hello world app for arm inserts a print definition above the main.
UI can see the xil_printf getting built in the BSP:
C:\Xilinx\14.1\ISE_DS\EDK\sw\lib\bsp\standalone_v3_05_a\src\cortexa9
Kind regards,
Gareth
There is a bug n the 14.1 stdio.h file, where the xil_printf declaration is missing.
To workaround this issue; either use the print function, Or manually copy the xil_printf declaration
into the GNU folder.
For example for on a  win7 install, firstly, open the Microblaze include folder and open the stdio.h file:
C:\Xilinx\14.1\ISE_DS\EDK\gnu\microblaze\nt64\microblaze-xilinx-elf\include
Then add the line below into line 230, in the stdio.h file.
Once this is done, clean all applications, and BSP's in SDK.
This issue is resolved in 14.2
Kind regards,
Gareth
Another way to get xil_printf is to declare it manually in your C source instead of including the header.  This is, instead of using
#include <stdio.h>
the function can be directly declared by using
void xil_printf(const char *, ...) __attribute__ ((format (printf, 1, 2)));
As a side effect, this provides an easy way to suppress all output (which I've found useful in some programs that don't run if xil_printf is used and the JTAG cable is not plugged) without deleting/commenting all lines with xil_printf (which are useful to keep for debugging purposes), just replacing that line with
#define xil_printf(...)
Right now this is the way I'm using on my C files.
P.S.:  Where is the xil_printf() declaration supposed to be now (14.2 and newer)?  Still in stdio.h, or has it moved somewhere else?
