xilinx sdk fatal error xil_printf.h no such file or directory
Hi team,
I'm new in Xilinx and I tried to make a test project following the instructions for Xilinx SDK creating a c project "Hello world".
As soon as the project is created it gives me errors such as xil_printf.h no such file or directory.
What might be wrong??
Hi @thrylos107,
Xil_printf is not a header file (xil_printf.h does not exist). You need to include "xil_io.h" header file which does include the xil_printf prototype.
Ibai
I have this exact same problem with the 2019.1 SDK, and the error even happens with Xilinx's own helloworld.c application project!
 It usually goes like this:
  1. I create a new BSP with a new FPGA build
  2. I change my own Microblaze standalone project to reference the new BSP
  3. I run launch the code on hardware and...
    1. The JTAG virtual UART mysteriously stops working and I have no way to interact with my code.
    2. Even launching the code in debug mode, main() is never reached.
  4. I do a full Clean of all projects and...
  5. I get the xil_printf.h error
This happens on code that was compiling and running just fine. Usually I have to close SDK, blow away my entire workspace, re-import all my C code, create the new BSP and then things return to normal.
However, I've had to do this about 10 times in the last couple weeks. Any ideas what could be going on?!
Tags (3)
