xilrsa library not found after clean
I was having an issue with SDK 2017.2 where anytime my fsbl bsp was cleaned and rebuilt the fsbl build would fail because the linker couldn't find the RSA library.
'Building target: fsbl.elf'
'Invoking: ARM v7 gcc linker'
arm-none-eabi-gcc -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -Wl,-build-id=none -specs=Xilinx.spec -Wl,-T -Wl,../src/lscript.ld -L"<path>\fsbl_bsp_0\ps7_cortexa9_0\lib" -o "fsbl.elf"  ./src/fsbl_handoff.o ./src/fsbl_hooks.o ./src/image_mover.o ./src/main.o ./src/md5.o ./src/nand.o ./src/nor.o ./src/pcap.o ./src/ps7_init.o ./src/qspi.o ./src/rsa.o ./src/sd.o   -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilffs,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilskey,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lrsa,-lxil,-lgcc,-lc,--end-group
c:/xilinx/sdk/2017.2/gnu/aarch32/nt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/6.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lrsa
collect2.exe: error: ld returned 1 exit status
make: *** [fsbl.elf] Error 1
This would occur only after I had cleaned the project, which I noticed would also fail with the below error.
rm: cannot remove directory `./': Permission denied
make[1]: *** [clean] Error 1
make: *** [ps7_cortexa9_0/libsrc/xilrsa_v1_3/src/make.clean] Error 2
make -C ps7_cortexa9_0/libsrc/xilskey_v6_2/src -s clean
make: Target `clean' not remade because of errors.
I noticed this only after upgrading to using xilrsa_v1_3.  It appears the Makefile included with xilrsa_v1_3 has a bug in it; line 57 needs to be removed as the librsa.a library is not built from sources, it is provided pre-built.  This line turns into "rm -rf ./" which kills the entire src directory and subsequent builds fail until you regenerate the bsp sources to copy the pre-built library back.
Not sure what the process is to submit a bug report to xilinx other than this forum but it would be nice to fix this in a future version.  My workaround for now is modifying the Makefile in the C:\Xilinx\SDK\2017.2\data\embeddedsw\lib\sw_services\xilrsa_v1_3\src directory so any new bsp that is made does not have this issue.
workaround:
@@ -37,22 +37,19 @@
 LIB=librsa.a
 RELEASEDIR=../../../lib
 INCLUDEDIR=../../../include
 INCLUDES=-I./include/ -I${INCLUDEDIR}
 LIBRSA_DIR = .
-OUTS = *.o
-OBJECTS =       $(addsuffix .o, $(basename $(wildcard *.c)))
 EXPORT_INCLUDE_DIR = $(LIBRSA_DIR)/include
 libs:
         cp $(LIBRSA_DIR)/librsa.a $(RELEASEDIR)
 .PHONY: include
 include: xilrsa_includes
 xilrsa_includes:
         cp -r ${EXPORT_INCLUDE_DIR}/xilrsa.h ${INCLUDEDIR}
 clean:
-        rm -rf $(LIBRSA_DIR)/$(OBJECTS)
         rm -rf $(RELEASEDIR)/$(LIB)
Re: xilrsa library not found after clean
Hi @bhig,
Thank you for sharing. I have already encountered this issue. It happens only on windows. I have created an AR but it is still not public yet.
It will be fixed in 2017.3.
Florent
Florent
Hi @bhig,
Florent
Florent
This issue reported by me internally and fixed in 2017.3,
Visitor srinixilinx
Looks like this problem exists atleast on 2017.1 and 2017.2. Is there a workaround without having to move up to 2017.3?
