cpandya90
xparamters.h file doesn't show address map of BRAM
Hi all,
I am working on project that will do data transfer from Block RAM to DDR memory through CDMA block.
In this I am doing two transfer process.
(1) from bram to ddr using processor
(2) from bram to ddr using cdma block.
For these processes I am using two separate block ram (1)bram0 for transfer using processor and (2)bram1 for transfer using CDMA block.
Here I have attached my xparamters.h file and block diagram of my project design.
In xparameters.h file, it only shows mapping of bram0 but doesn't show mapping of bram1.
Can anybody help me out.
Thank you.
Tags (4)
stephenm
Only the address map for the processor will be shown in the xparameters.h.
 You can just manually define this in your application
stephenm
