xps cip wizard
Hello everyone! I have a question :can i connect this PLB bus signal "BUS2IP_Clk" to some module that locate outside MB module ? Because i want to use the clock signal to write some data to DPRAM.
Re: xps cip wizard
Check this link
http://www.fpgadeveloper.com/2008/10/create-peripheral-using-peripheral.html
Thanks and Regards
Balkrishan
Re: xps cip wizard
hi,
bus2ip_clk is an input clock. can you brief the use case here?
--hs
Re: xps cip wizard
Check this link
Thanks and Regards
Balkrishan
